Overview
Coding that will scan a 2D String Array and prompt the location for the first numeric value in it.
Description
The VI uses the lexical class function to determine if the characters in the cell are numeric or not. If there are numeric characters, then the execution will be stopped. The indicators will show at which row and column we found the numeric value. We need to consider that it is zero indexed in order to verify the answer.
Requirements
LabVIEW 2012 (or compatible)
1. Fill the 2D Array as desired.
2. Select the Run button.
3. Verify that column and row prompted to validate answer.
Additional Information or References
