Overview
X Series cards have a new feature that enables you to have delay on each retriggerable pulse train you want to generate.
Description
X Series cards have a new feature that enables you to have delay on each retriggerable pulse train you want to generate. X-series technology also only requires one counter to produce a finite retriggerable Counter Task, as opposed to M/E series boards which automatically allocate two counters on the board. Just by setting the Initial Delay in your channel properties, the delay will only be seen on the first trigger to start the task. By using this VI, the delay will be on every pulse train from when it receives the start trigger.
Requirements
Software
LabVIEW 2011 or later
DAQmx
Hardware
X Series Multifunction DAQ Device
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
