Example Code
Finite Sampling Progress Bar & Automatic Scale Adjustment
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI allows you to view the "real-time" progress when acquiring a finite number of samples by the means of a graphical progress bar.
Description
 Based on the data entered by the user, the VI will automatically scale the chart x (time) axis to fit exactly with the number of samples acquired. The progress bar scale values are also updated in a similar fashion.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Download both attached VI's. Configure Timing & Scales is a sub VI within the Sampling Progress VI.
  2.  Specify your Channel to sample.
  3.  Specify the sampling rate and number of samples (refresh rate should generally be left, updating beyond 50Hz will not be noticed by the user and is likely to cause problems).
  4.  Run the VI.
  5.  Experiment with altering the number of samples and rate of acquisition.
Additional Information or References
