Overview
This VI demonstrates the way of triggering a event structure using data in a file.
Description
An event structure can be very helpful when needing to "watch" for a user input and react to that input. In some applications, you may want that event structure in place, but also the functionallity of inputing data from a file. This simple VI demonstrates how this is possible. This also can be used with Simulation Interface Toolkit to fire the events needed from a file. The trick is to use a property node of the control and write to the Val(Sgnl)instead of just Value. The first option fires that event that you need.
Requirements
Software:
1. Modify the data in data.txt file
2.Run the VI
Additional Information or References
VI Block Diagram
