Example Code
First Order Delta Sigma VI
Code and Documents
Overview
This VI is intended as an instructional tool to illustrate how a 1st order 1 bit delta sigma ADC works.
Description
Inside the block diagram of 1stOrderDeltaSigma.vi you'll see the main components of a DS ADC- integrator, comparator, and a 1bit DAC followed by a low pass filter. On the front panel you can set the oversampling rate as well as the reference voltage for the feedback signal to see how these affect the signal to noise ratio (SNR). A graph of the analog signal and the sampled signal are displayed as well as the analog signal and delta sigma modulated signal.
Requirements
Software
  • LabVIEW 2012 or compatible
  1. Specify the reference voltage for the feedback digital to analog (DAC) signal and the oversampling rate。
  2. Run the VI.
Additional Information or References
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
Comments
xourlingkahn
Member
Member
on
Sub VI "GetPlots.vi" is missing or non existing in LV2010 Student Ed. ... could not run the VI ... what a shame!
anybody please could supply GetPlots.vi ??
Sean_F
NI Employee (retired)
on
Hi Xourling,
Sorry about that. I couldn't find the VI on my computer so I'll try and
recode that when I get a minute. All the VI did was merge the DS output
with the original signal.
Sean Ferguson
RUNSLOWLY
Member
Member
on
Hi, i also met the problem about the floor 1 reader.
I'll waiting for your answer.
xourlingkahn
Member
Member
on
yes indeed, I suspected that subvi GetPlots.vi was just collecting the input and output signals for plotting, but as I´m still quite new to Labview I can not yet implement these kind of simple things. If you could fix the problems and provide a working version of your code it would be great!!
