This example contains an NI FlexLogger project, configuration file for simulated hardware, examples to control NI FlexLogger via Python, and getting started documentation.
The Load Project (Load Project.flxproject) is a FlexLogger project that provides a reference for taking load and pressure measurements through NI FlexLogger and contains the following predefined FlexLogger documents and files:
FlexLogger Channel Specification
FlexLogger Screen
Note: The Load Project has been configured to acquire data from specific load cells and pressure sensors. If different sensors are present, the configuration will need to be modified to reflect the correct sensor configuration.
Description-Separate-2
Project Execution Buttons
Note: For additional information on the components, configuration, and how to customize the template, open the Getting Started file located inside the Load Template.zip file.
How-Separate-2
Related-Separate-2
