This example contains an NI FlexLogger project, configuration file for simulated hardware, examples to control NI FlexLogger via Python, and getting started documentation.
The Mixed Measurement Project (Mixed Measurement Project.flxproject) is a FlexLogger project that provides a reference for taking voltage, current, temperature, and digital measurements through NI FlexLogger and contains the following predefined FlexLogger documents and files:
FlexLogger Channel Specification
FlexLogger Screen
Note: The Mixed Measurement Project has been configured to acquire data from specific voltage transducers, pressure sensors, thermocouples, and digital lines. If different sensors are present, the configuration will need to be modified to reflect the correct sensor configuration.
Description-Separate-2
Project Execution Buttons
Note: For additional information on the components, configuration, and how to customize the template, open the Getting Started file located inside the Mixed Measurement Template.zip file.
How-Separate-2
