This example contains an NI FlexLogger project, configuration file for simulated hardware, examples to control NI FlexLogger via Python, and getting started documentation.
The Temperature Project (Temperature Project.flxproject) is a FlexLogger project that provides a reference for taking temperature measurements through NI FlexLogger contains the following predefined FlexLogger documents and files:
FlexLogger Channel Specification
FlexLogger Screen
Note: The Temperature Project has been configured to acquire data from specific K-Type thermocouples. If different sensors are present, the configuration will need to be modified to reflect the correct sensor configuration.
The attached zip file also includes examples to control NI FlexLogger via Python. Refer to the included PDF or Read the Docs link below for more information.
Description-Separate-2Project Execution Buttons
Note: For additional information on the components, configuration, and how to customize the template, open the Getting Started file located inside the Temperature Template.zip file.
How-Separate-2
Related-Separate-2
