Example Code
FlexRIO SPI Example - Simulation and Real IO
Products and Environment
    Operating System
  • Windows
    Programming Language
  • LabVIEW G
Code and Documents
Third-Party Code Repository
Some users manage their code in repositories outside of ni.com. Use your best judgment when following links to third-party sites. https://download.ni.com/evaluation/labview/lvtn/vipm/packages
Description
This example showing a SPI implementation on NI FlexRIO with digital FlexRIO Adapter Module. The implementation is bassed on NI SPI IP. You can run this example in simulation mode or with real IO.
How to Use
  1. Download the attached .zip file and unzip the file.
  2. Install the NI SPI IP with help of the VI-Package Manager. You can either search in the VI-Package Manger for NI SPI IP or you can use the package in the following location: Exercise>>FlexRIO SPI Example with Simulation>>NI SPI IP for offline installation>>national_instruments_lib_ni_spi_ip-1.3.0.1.vip
  3. Open the FlexRIO – NI SPI FPGA Simulation.lvp
    Open the VI in project FlexRIO - NI SPI FPGA Simulation and Real IO - FPGA.vi and analyze the Frontpanel and Blockdiagram.
    Note:
    - The FPGA Execution mode is: Simulation
    - All hardware related funktions are disabled by using conditional case structures.
    - The SPI Master and Slave are connected in the Master/Slave Connection loop via Local Variables and Wires instead of using a physical connection.
  4. Run the VI, change the values in the Master Data Write and Slave Data Write controls. Press the Start button to send the new values.
  5. Stop the VI.
  6. For better understanding how SPI works, open FlexRIO - NI SPI FPGA Simulation - Host.vi and run it. This VI running cycle accurate the FPGA Simulation and show the signals in a Digital Waveform graph.
  7.  Stop the VI
  8. For using Real IO, only switch the Execution mode to FPGA Target and compile the FPGA VI.
  9. Connect the four DIO lines Chip Selecct, Clock, MOSI and MISO to get a loop back setup.
  10. Run the FPGA VI again. Please note that the Simulation VI on My Computer (host) only working win simulation mode.
Note: If the FlexRIO boad or the adapter module don’t fit to your setup and you want to use another Digital FlexRIO Adapter, add both to the project and copy or move the FPGA files to the new target.
Additional Information
Software
  • LabVIEW 2020 or higher
  • LabVIEW FPGA 2020 or higher
    • FlexRIO with Modular I/O 20.0 or higher
Hardware
  • NI 797xR + NI 6581B adapter module (NI 6583 would also work)
  • SHC68-C68-D4 cable
  • SMB-2163 + 4 SMB cables or CB-2162
Related Links
Helpful Knowledge Base: Understanding the SPI Bus with NI LabVIEW.
