Example Code
Flexible DAQmx State Machine for Automated Tests
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI shows how to use a State Machine with an array of steps to run throguh a pre configured list of steps.
Description
This Example shows a process where we turn a heater on, then measure a finite numer of samples then tunr the heater off.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Set the Physical Channels for a digital output and analog input.
  2. Configure the Steps from a list of States dropdown.(to add new states right-click the dropdown and select Open Type Def and Edit the Elements)
  3. Set the Numer of Samples thenrun the VI
Additional Information or References
Comments
Philip1
Member
Member
on
This looks like exactly what I need.
I am using LabVIEW 2010 base. Is the base package enough to run this VI??   I am informed (while loading) that "State Type def .ctl" is missing (or isn't where its should be).
Thank you-
Tiger3D
Member
Member
on
Please add "State Type def .ctl". Otherwise it looks great. Thank you.
JTShaw
Member
Member
on
Please add "State Type def.ctl"
HunterSeeker
Member Member
Member
on
I added the type def, should be good to go now.
