Example Code
Flip-Flop
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This VI is a simple implementation of a flip-flop in LabVIEW.
Description:
This program sets an LED (labeled Switch) to True when Line 1 transitions from True to False. When Switch is true, changes to Line 1 won't affect Switch until Line 2 resets Switch by transitioning from True to False. At that time Switch is turned off and can be turned on by Line 1 again.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Click the Run button.
2. Notice that toggling Line 2 does not affect the state of the Switch Boolean.
3. Click on the Line 1 button to put it in the True state.
4. Click on Line 1 again to cause it to transition from True to False.
5. Notice that the Switch Boolean is now set to True and that further transitions of Line 1 do not affect the state of Switch.
6. Toggle Line 2 from False to True then back to False.
7. Notice that the Switch Boolean is now set back to False.
8. At this point the VI is back to its initial state.
Additional Information or References:
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
