Example Code
Floating Point Number over Modbus TCP
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
How to send single precision floating point numbers through modbusTCP (U16)
How to Use
You should always run the Slave VI first and then the Master VI. To finish, press the "Stop" button on the Master VI and then do the same on the Slave VI.
Additional Information
Must have NI Modbus installed.
