Overview
This VI emulates a triangle screensaver and shows the area of its triangle over time, providing a generator of slow-rate random analog waveforms.
Description
Who of you never looked at the triangle screensaver and wondered how the area of that moving triangle would vary over time? Using basic maths and LabVIEW capabilities, the answer is now on your screen!
Drawing a triangle each 50 ms according to initial angles set by the user on front panel, this VI emulates that well-known Windows screensaver, calculating the area of each of these triangles and plotting it on a waveform chart.
While originally designed without any practical purposes, ‘just for fun’, it can also be used for test as a slow-rate random analog waveform generator.
As far as I know, I've invented a completely new kind of circuit in Electronics.
Differently from standard waveform generators, based on some predictable and boring behavior of a physical material, like crystal-based oscillators, it provides you random waveforms by its own nature, eliminating the need of storing real-world signals in a deep memory as in an arbitrary waveform generator. Changing starting angles and frame dimensions (the 'oscillator' section), you can obtain different curves (for further studies). Using smaller steps and cycle times, you can obtain better resolutions. Let's try it!
Nice comments and suggestions are welcome.
Requirements
Software
Made in LabVIEW 2015.
Hardware
N/A
Additional Images or Video
