Overview
Since LabVIEW doesn't have a programmable start button, this example VI uses a method to create that effect.
Description
It uses two states, an "Active" and "Idle" state. The VI is set to run when opened, and hence is in the "Idle" state when started. When the Start button on the front panel is pressed the VI changes to its "Active" state. Pressing the Stop button will return it to the "Idle" state.
Requirements
Additional Information or References
VI Snippet
Please, Can you post the VI in LabVIEW 2009??
