Example Code
Functional Global Variable to Scale Output Using LabVIEW
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
The example shows how to use a functional global variable to change an output based on some input (in this case a Digital Input).
Description
You can run the VI to get the calibration (scaling) coefficients of your specified device using DAQmx property nodes.
Requirements
  • LabVIEW 2012 (or compatible)
  • NI DAQmx 12.0 (or compatible)
1.Write datum in the Voltage Setpoint control, Voltage Endpoint control and Cycles control.
2.Select the channel of Digital Channel to Read control and External Clock Source control.
3.Run the VI
Additional Information or References
NI Snippet
ColeR
Field Engineer
