Overview
The example is to demonstrate how to how to generate tone and noise in the Analog Output pin
Description:
By using the producer and consumer design pattern, the VI shows the benefit of using queue to generate tone and noise. The producer would queue the generated noise while the consumer would access the DAQ Analog Output to generate the signals
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Output Module
