Example Code
Generate Frequency Hopping Bluetooth Signal and Measure CFO
Code and Documents
This example shows how you can use the List Mode feature in NI RF Signal Generators to generate a frequency hopped Bluetooth Signal and how to do Carrier Frequency Offset (CFO) measurement.  Example is saved in LV2010SP1.  You need to install Bluetooth Toolkit 1.0
Contributors
