Overview:
Demonstrates on generating pulses on every Digital Output lines.
Description:
This code will continuously generates 8xN array of Booleans, with N points per period using onboard clock.
Note: Using the counter method of generating a PWM output is recommended.
Requirements:
Steps to Implement or Execute Code:
Can anyone post the picture of the 8chansoftwarePWM.vi? Or it would be greatly appreciated if the program could be saved for proper open using Labview 7.1.
