Overview
This example shows how to generate a voltage output from a file that contains the timestamp (in seconds) and the voltage values.
Description
This example shows how to generate a voltage output from a file that contains the timestamp (in seconds) and the voltage values. This example is meant for files with varying intervals between each timestamp.
Requirements
Software
Hardware
Additional Information or References
This example is not meant for deterministic signal generation. You will notice that each iteration of the loop will take about 1-2ms longer than the calculated time delay.
