Example Code
Generate and then add to or augment an error message
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI modifies the description of the error to include additional information.
Description
This code generates a built in error i.e. 356677, and then allows the error to be augmented with custom information, whilst still preserving the original error data
Requirements
  • LabVIEW 2012 (or compatible)
  1. Specify the Source in "Additional error information";
  2. Run the VI.
  3. Check the error popup window.
Additional Information or References
VI Block Diagram
Chris | Applications Engineer NIUK
