Overview
Generation of a cyclic prefix for an OFDM baseband signal.
Description
Cyclic prefixes are used as a guard interval when we have channel imperfections causing the signal to be delayed. In order to create this prefix, we need to take out the last part of the signal and added at the beginning of the OFDM. The amount of information added is dependent of the user or receiver. Normally, the receivers discard these prefixes, however is a great tool to maintain the protect the signal.
Requirements
LabVIEW 2012 (or compatible)
1. Open the "Cyclic Prefix Generation for a OFDM scheme LV2012 - NI Verified.vi"
2. Select the amount of signal that you would like to add as the prefix. Please note that is a percentage.
3. Verify the OFDM baseband is the desired one.
4. Run the code.
Additional Information or References
