Example Code
Get Array Names from Cluster
Code and Documents
Overview:
Shows how to get the name of Arrays in a cluster.
Description:
This code uses property nodes and classes references to get the name of the arrays present on a Cluster.
Requirements:
LabVIEW 2012 or compatible.
Steps to Implement or Execute Code:
1. Run the VI.
2. Check in the indicator that only the names of the Arrays are present.
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**".
Dan King
Comments
DanRichards
Member
Member
on
Outstanding!
Dan Richards
Certified LabVIEW Developer
