Example Code
Get Caps Lock Key State Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The Get Caps Lock Key State VI returns the current state of the Caps Lock key.
Description
The VI calls the Windows API (User32.dll) and uses the GetKeyState function to get the current key state. The VI outputs the current key state as a numeric and also as a descriptive text string.
Requirements
  • LabVIEW 2012( (or compatible)
  1. Change the state of Capslock  key
  2. Run the VI
Additional Information or References
Front Panel
VI snippet
