Retrieve the ProjectItem reference of an item in your project by name.
Retrieves a ProjectItem reference to an item specified by name under a specified TargetItem in the project. If a TargetItem reference is not wired to this VI, then the My Computer target under the specified Project Refnum is used instead. If multiple items with the same name exist under the specified TargetItem in the project, the reference to the first item found will be returned.
LabVIEW 2013 or compatible
Use this VI in your own application for obtaining a ProjectItem reference by Name.
