Example Code
Get Section of Waveform Channel in DIAdem
Products and Environment
    Software
  • Diadem
Code and Documents
Description
Overview
This VB script will create a new waveform channel from a section of another channel while keeping the time data intact.
Description
The VB script follows this KnowlegeBase article. This example is a workaround because DIAdem does not save the time data when you make a new channel from a section of waveform data. The next edition will include using the cursors or flags to identify what section of the Waveform channel to duplicate.
Requirements
  • DIAdem
  1. Open in DIAdem SCRIPT
  2. Change constants as needed
  3. Load channel you with to take a section of
  4. Set Active Channel Group in Data Portal
  5. Run script
  6. See new channel that is generated by the script
