Products and Environment
	Code and Documents
						Description
Description-Separate-1This example explains how to get the serial number and other information of NI hardware programmatically.
Description-Separate-2How to Use
How-Separate-1
- For all NI devices
NI System Configuration API can be used to get the serial number of NI hardware devices.
Download the example Get_Hardware_Info.vi for more detail.
- For NI DAQ devices
- The serial number could be acquired by DAQmx property node. In the function palette of the block diagram, the "Device Node" could be found at Measurement I/O > Advance > I/O Constant > Device Node.
- Choosing the information needed by clicking the Device Node and select in the Identification category
- Assigning the DAQ device and executing the vi would get the information of the DAQ hardware.
How-Separate-2Related Links
Related-Separate-1
Related-Separate-2
