Overview
This example programmatically identifies the model of each module in a chosen cDAQ chassis.
Description
The code uses the DaqSystem class to load the chassis as a Device object. Then, a foreach loop iterates through the list property ChassisModuleDeviceNames. Each module is loaded as a Device object using the DaqSystem class. The ProductType property of the module object returns the string that indicates the module type, which is added to the list of modules.
Requirements
Software
Hardware
Additional Information or References
Form
