Overview
This game is simple. Match the given graph. You can take the detail in File - VI properties - Documentation.
Description
You are given the ability to adjust the frequency and amplitude of two sin waves. The two waves are added together and displayed to the screen. If you can not solve it just hit the help button and the Global Optimization VI will solve it for you and show you the correct amplitude and frequency needed for the graph. The Global Optimization VI uses a genetic algorithm. To learn more about genetic algorithms check out Wikipedia. For this example, the algorithm is given an objective function that calculates the average difference between a guess and the graph to match. This optimization VI can be used to solve many problems where there are set objectives and constraints given a finite number of inputs. I hope this example is fun and interesting.
Requirements
Additional Information or References VI Block Diagram
VI Block Diagram
