Overview
Generates and graphs x and y data for an ellipse in which the horizontal axis, vertical axis, angle, and left and rightmost point are customizable.
Description
This VI outputs an ellipse to an XY Graph using the formula node and the equation for an ellipse. The values for a, the horizontal axis, b, the vertical axis, are controlled by the user. The user can also control the location of the left and right most points on the ellipse using x1 and x2 and can control the vertical offset using the y control. The angle of the ellipse is controlled after the formula node by applying a rotation formula to the x and y values. Y values are created for all quadrents of the XY Graph, put into an array, and then put into the XY Graph.
Requirements
Software:
Additional Information or References
NI Snippet
