Overview
This example demonstrates how to perform a source synchronous dynamic generation and acquisition on a single high speed digital device.
Requirements
Software
LabVIEW 2012 (or compatible)
NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
Hardware
NI-HSDIO devices
Instructions
1.Before running this example, please use equal length cables to make the following connections on the terminal block:
2. Select File.
3. Run the VI.
Note
Make sure to set the file path the the Data text file. Also, make sure to connect PFI 1 and 2 with a jumper cable
Additional Information or References
