Example Code
HTML and CSS Syntax Highlighter
Code and Documents
Overview
This example demonstrates how to syntax highlight HTML and CSS strings using native LabVIEW controls (No ActiveX or .NET). While highlighting in LabVIEW is not difficult, formatting native LabVIEW strings are notoriously slow (compared to referenced based languages). With a few optimizations I was able to get the redraw rate below 100ms for a ~20kB file (Minimal typing lag).
Example
Unzip and run the SyntaxHiLite.vi example. Press the 'HTML' or 'CSS' buttons to generate example strings. While typing the example is optimized to only update the highlighting after a tag is close (i.e. '<..>' or '{..}'). This helps reduce redraw lag. HTML strings highlight tags, attributes and comments while CSS strings highlight styles and comments.
Block Diagram
The SyntaxHiLite String.vi optimizes string value change and key down events to determine when to update the display.
Requirements
- LabVIEW 2013 or later
Author
Ryan Pacini
Certified LabVIEW Architect | RyLabs.com
Contributors
