Example Code
Handling Events Generated in a SubVI Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to handle events that are generated in a subVI
Description
If you are familiar with handling user interface events by using the event structure in the same VI, this VI shows how to handle events that are generated in a subVI. Sometimes we want to have the ability to handle events that are generated in a subVI, one or more, in a way that enables the Main VI responding to different types of events , from a different types of resources. This VI shows how to implement such application.
Requirements
LabVIEW 2012 (or compatible)
Steps to Complete
  1. Open the code and run the main VI. A sub VI will pop up.
  2. Click the "Clicky" button, and observe that both the sub VI front panel, and the main VI front panel are being updated with the number of clicks.
  3. You can dynamically register for events if you have the reference for the control or for the user event that you want to register.
  4. Because we can get control references to controls in any VI, we can register for events in any VI.  You can then use the event structure in the main VI to handle it.
Additional Information or References
VI Block Diagram
Handling Events Generated in a SubVI LV2012 NI Verified BD1.jpgHandling Events Generated in a SubVI LV2012 NI Verified BD1.jpg
Handling Events Generated in a SubVI LV2012 NI Verified BD2.jpgHandling Events Generated in a SubVI LV2012 NI Verified BD2.jpg
**This document has been updated to meet the current required format for the NI Code Exchange. **
Wes Pierce
Principal Engineer
Pierce Controls
Comments
crewx
Member
Member
on
This doesn't seem to work, there is also no documentation in the vi explaining what is going on, or what is supposed to happen.
Fail
JW
Wes_P
Member
Member
on
Hi crewx,
Please take a look at this again.  The wrong version of the code got uploaded by accident the first time around.
Wes Pierce
Principal Engineer
Pierce Controls
