Overview
This example shows how to generate synchronized digital data with multiple HSDIO devices using only one HWS File.
Description
This example demonstrates how to setup an acquisition designed to capture 1000 samples. In the event that the device times out and doesn't receive a reference trigger, the code will handle that error and acquire 100,000 samples relative to the first sample. This is a way to dump the memory in the case that you don't receive a trigger.
Requirements
Software
LabVIEW 2012 (or compatible)
NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
Hardware
PXI-655x
Instructions
1. Select HWS file.
2. Run the VI.
Additional Information or References
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
