Example Code
Hide Clusters on the Front Panel Using "Visible" Property Node Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example program allows you to hide and bring back clusters using event structures and the implicitly linked "Visible" property node.  This program could be useful when trying to create a program that only has certain functionality available to the user when necessary. Another option would be to use tab controls.
Description
This example initially hides two clusters on the front panel during runtime when the user presses the reset button. When the user presses "Generator 1," the Signal Generator 1 cluster appears. When the user presses "Generator 2," the Signal Generator 2 cluster appears. This all occurs with an event structure and implicitly linked property nodes. The visible property node can be used for any front panel object and can be implemented in the same manner as this example. It is found by right clicking on the control, Create>>Property Node>> Visible.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the program
  2. Press the reset button and both clusters will be hidden.
  3. Press the Generator 1 button and the Signal Generator 1 cluster appears. You can change the values of frequency etc.
  4. Press the Generator 2 button and the Signal Generator 2 cluster appears
  5. Hit the stop button to complete your test
Additional Information or References
VI Block Diagram
