Example Code
Hide File orFolder Programmatically
Code and Documents
Overview
Demonstrate the use of Call Library Function Node to hide a file or folder.
Description
This VI makes DLL call to change the status of a file or folder to be hidden. It passes the directory information to Call Function Library node that has been set up in windows. You can use this VI to convert a file or a folder’s visibility by simply put a path.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI " Hide File Programatically 2012 NIVerified.vi”
  2. Run the program
Additional Information or References
VI Snippet
Matt Surridge
