Overview
This VI hide the main user interface panel when the user is interacting with a subVI user interface
Description
In many applications, it may be desirable to hide the main user interface panel when the user is interacting with a subVI user interface. Doing this can reduce clutter on the desktop and add focus to what the developer is trying to direct the user's attention to. The attached project implements a simple framework for hiding the main user interface panel when the user is interacting with a subVI user interface. The main purpose of this example is to demonstrate this functionality.
Requirements
LabVIEW 2012 (or compatible)
Additional Information or References
SubVI Block DiagramHIDE SUB VI BF.jpg**This document has been updated to meet the current required format for the NI Code Exchange. **
front panel transparency increases a little bit the system consumption, use invoke node to make the front panel minimize may be a better solution.
I think this is very length process to Hide the main VI during run of Sub VI.
Simply we can use propert node(Front Panel Open).
First thing is get the Main VI Refnum and passed to Sub VI In Sub VI by using that Refnum we can close the Front Panel of the Main VI.
Then When ever we exit the Sub VI at that time , By using that Refnum We can Open that Main VI Front Panel.
Once you Try.....
Wes, There are just one or two issues with your implementation. Since this example was mentioned in another thread on the LabVIEW forum I took the time to clean up the project and use a slightly more robust framework. The project is attached in the thread linked below. Thanks for the nice example.
https://forums.ni.com/t5/LabVIEW/Show-children-windows/m-p/2609111#M782845
