Example Code
High-Speed Trigger and Acquisition System based on NI PXIe-5764
Products and Environment
    Hardware
  • PXIe-1095
  • PXIe-5764
  • PXIe-8861
    Software
  • LabVIEW 2021 SP1 Full
  • LabVIEW FPGA Module
    Other
  • Flex-RIO
Code and Documents
Description
This Demo demonstrates how to acquire signals using the PXIe-5764 digitizer and perform signal analysis on FPGAs, such as FFT transformations. The demo system is composed of PXIe-5764 digitizer, PXIe-1095 chassis and PXIe-8881 controller, which can simultaneously collect data from 4 analog channels at 1GS/s sampling rate, with analog trigger, digital trigger, custom software trigger and other trigger functions, and the single-channel trigger frequency can reach 1MHz.
How to Use
  1. Download and unzip the attached ZIP-file
  2. Open PXIe_5764_Demo LabVIEW project and build the 5764_FPGA_FFT_DEMO.vi
  3. Open the [Host] PXIe-5764 Demo Host.VI inside the LabVIEW project and follow the instructions on the Front Panel
Additional Information
Contributors
