This VI will allow you to combine images opened from disc.Once the images are combined the new image will be written to disc.
Caveats and Additional Notes If the images are not the same size the combined image will take the vertical size of the largest image and fill the empty space as black.You may combine as many images as needed.
Adam H National Instruments Applications Engineer
