Example Code
How can I check the Serial Number of a Device using LabVIEW?
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example works to directly query the serial number of the device.
Description
To query the serial number on your own simply place the DAQmx Device Property Node by right-clicking on the Block Diagram to open the Functions Palette, navigate to All Functions»Measurement I/O»DAQmx»Advanced»System Setup and select a DAQmx Device Property Node. Create a constant for an ActiveDev. This will be where you select your device. Expand the property node down one level, and select Identification»Device Serial Number and create an indicator so that you can see the resultant number.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
1.Select your Device Here.
2.Run the VI.
3.Get the Serial Number of Device.
Additional Information or References
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
Comments
Kirinos
Member
Member
on
I just used this on two different PCI 16XE-50 boards in the lab. They both returned the exact same code. Are device serial numbers supposed to be unique?
