Example Code
How can I load and save a generic configuration file for my VI?
Code and Documents
Introduction
Here's an example on how to load a configuration file that has values to be used in the running of the VI and save the values at the end of running.  For example, this allows you to, as in this example, load calibration constants at the beginning of the VI.  You can then allow for these to be changed over the course of running the VI.  Finally, these new values will be written back to the configuration file.
Steps to Complete
First, you load a spreadsheet file and set the values to the controls.  The VI runs after this, during which the values can be changed.  Finally the values are saved back to the file.
Jared S.
Applications Engineering
Contributors
