Overview
This VI shows how to programmatically change the color of decorations in the front panel.
Description
In some applications, it is necessary to change the color of a decoration on the front panel programmatically. This program demonstrates this concept using property nodes.
To change the order of front panel decorations, refer to Knowledge Base 2RAFGB5A: Can I Change the Order That I Placed Decorations on My Front Panel?
Requirements
LabVIEW Base Development System (or compatible)
1. Select the color you would like to use.
2. Run the VI
Additional Information or References
deleated
