Overview
This example shows how to combat channel switching caused by FPGA FIFO overflow.
Description
When sending multiple channels of data over an FPGA FIFO it is common to interleave the data. Unfortunately, if an overflow occurs, channel switching can also occur, as the interleaved data is decimated in the wrong order. To combat this the data from multiple channels can be combined together into one larger element. Whilst this method does not prevent data loss (see articles on increasing FIFO size and depth for help with this matter) it does mean that if overflow occurs, channel switching is prevented as all data points will be removed.
Requirements
Additional Information or References
VI Block Diagram
This works if you have 4 channels. If you want to use N channels: On the FPGA, first check the available FIFO space before adding elements. If space is available, then add your array of channels.
On the host side, you do things as usual : grab a number of samples that is a multiple of the number of channels.
