Overview
This VI will find the frequency and phase difference between an array of waveforms, and can be used to test your system's synchronization quality.
Description
When trying to synchronize several signals, it is important to find the max phase difference between your signals in order to determine the level and quality of your synchronization. This VI allows you to put an array of waveform data into the "Signals" section and obtain the frequency, phase, and phase difference of your input signal.
Requirements
Additional Information or References
VI Snippet
Screenshot of using as a SubVI
