Example Code
How to Handle an Array of Pointers for LabVIEW DLLs
Code and Documents
Overview
This example shows what must be done when you have a DLL that requires an array of pointers as one of its inputs.
Description
It shows how to use a wrapper dll to create this array of pointers that you will need to input into the parameter of your function. It also includes the C file for the wrapper dll used for this integer example which was written in Visual Studios.
Requirements
LabVIEW 2012
Visual Studios
Steps to Execute Code
1. Extract all files onto your computer.
2. Make sure that the DLLs are referencing the write location on disk for the WorkingWithBuffersExampleDLL.dll
3. Read through the comments on the VI to understand how each part works to get a good idea of how you might implement this with your own code.
4. Run the code to observe the behavior.
Kaitlin N.
