Example Code
How to Programmatically Launch MAX Test Panels From LabVIEW for a Local Device
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
Code and Documents
Overview
Sometimes a user simply wants to see the output of a DAQ devices and is uninterested in logging that data or getting specific values. In this case it's appropriate to simply launch a MAX test panel to quickly look at what a DAQ card can do.
Description:
This VI will allow a user to launch a MAX test panel from the command line. This example is inspired from this Knowledge Base Article: http://digital.ni.com/public.nsf/allkb/9B628A8B1B13136F86256DDB0004DE4D
Steps to implement or execute code
To implement this example:
  1. Set the path to nidmfpan.exe
  2. Select the DAQ device you'd like to use
  3. Press run
  4. When complete, close the window and the VI will automatically stop
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware
  3. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Module
Bobby Breyer
