Example Code
How to Query Your COM Ports for a Particular Device
Products and Environment
    Hardware
  • Other
    Software
  • LabVIEW
    Driver
  • NI VISA
Code and Documents
Overview
This example VI can be used to programmatically identify which COM ports are connected on your machine.
Description
First, the VI identifies each machine that is connected to the COM ports using the *IDN? command. The nested Case Structures in the VI can be used and modified to perform any desired actions based on the acquired information from the COM ports.
Requirements
  1. LabVIEW 2012 or later
  2. NI-VISA Driver
  1. Specify the Expected COM Port on the Front Panel
  2. Run the VI
Additional Information or References
VI Snippet
Comments
Jousepa
Member
Member
on
bytes at port, someone is gona get angry
crossrulz
Knight of NI Knight of NI
Knight of NI
on
I'll just drop this link here...VIWeek 2020/Proper way to communicate over serial
Jousepa
Member
Member
on
hahhahaha no way
