Example Code
How to programmatically query information from the C-Series modules off a cRIO
Products and Environment
    Hardware
  • CompactRIO|SingleBoardRIO
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to query programmatically the C-Series modules in a cRIO and get the available inputs/outputs.
Description
It is sometimes necessary to query information from the C-Series modules used in a cRIO/sbRIO. This information can be used for documentation purpose or to write custom tools.
This example shows how you can gain this information through the use of property nodes from the LabVIEW-Project.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • cRIO/sbRIO Real-Time target
  1. Download and open the attached ZIP-file
  2. Open the LabVIEW-Project and follow the instructions in the VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
