Example Code
How to programmatically read variable names and descriptions in Compact RIO Scan Mode
    Software
  • LabVIEW Real-Time Module
Code and Documents
Overview
This example demonstrates how to programmatically read variable names and descriptions in Compact RIO Scan Mode.
Description
When we have a CompactRIO (cRIO) in a project and we are using the Scan Interface (Scan Engine) for the modules, it is always good to rename the channels (IO) with names meaningful to our application. These names can be extremely useful during logging or during data presentation to the user. Here is a way to extract these names programatically and also extract the descriptions as well!
Note: (IO descriptions are accessible statically by right-clicking on the IO of the module, and going into its Properties. In the Description section you can check "Enable Description" and add information for that IO)
Requirements
 Software
  • LabVIEW Full or Professional Development System 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • Compact RIO (e.g. 9074 or compatible)
  • Any C Series module (e.g. NI 9211 and NI 9474 or compatible)
  1. Download and extract the attached file "Extract C Series IO Names in Scan Mode LV2012 NIVerified.zip"
  2. Close all open LabVIEW projects
  3. Open Project "Extract C Series IO Names in Scan Mode LV2012 NIVerified.lvproj"
  4. Follow the instructions in Front Panel and Block Diagram of "Extract C Series IO Names in Scan Mode LV2012 NIVerified.vi" and run the program
Additional Information or References
Project:
VI:
Extract C Series IO Names in Scan Mode LV2012 NIVerified.vi - Front Panel.pngExtract C Series IO Names in Scan Mode LV2012 NIVerified.vi - Front Panel.png
Extract C Series IO Names in Scan Mode LV2012 NIVerified.vi - Block Diagram.pngExtract C Series IO Names in Scan Mode LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
sahpe
Active Participant
Active Participant
on
If you need these lists as 1D arrays instead of 2D then this is a simple tweak! Have a look at "IO info 2.vi" for an example on the names.
sahpe
Active Participant
Active Participant
on
If you need an array of all of the values on a single module, then this will help:
NI Scan Engine Advanced I/O Access
