Overview
This VI generates a random value for the humidity within a given range. The humidifier is then programmed to turn on at a Lower Limit. The humidifer will then stay on until the humidity reaches a value greater than the upper limit. This allows the humidity to vary randomly in the range between the upper and lower limit.
Description
Use the Humidity Range input to specify the range that the randomly generated humidity will be within. Use the Upper and Lower Limits to specify when the Humidifer turns on.
Requirements
Additional Information or References
VI Block Diagram
