Example Code
IBM Rational ClearQuest Example VI
Code and Documents
Overview
This VI is used to use the Clear Quest API
Description
Using the ClearQuest API (found here) this VI performs some simple steps:
- Log on to the ClearQuest server
- Get valid Entity Definition Names (for clarification)
- Create a new Entity, validate (against mandatory fields), then commit to the database
- Sign the user off
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attachment to your computer
  2. Open the VI "Add New Entity 2012 NIVerified.vi"
  3. Run the VI
Additional Information or References
VI Snippet
